What would be involved with adding some methods to compile c programs in memory and upload them to the kflop.
I am working on a small framework to create function blocks that generate c code and would like to bypass the file IO latency.
Thoughts?
-Brad Murry
Group: DynoMotion
Message: 4281
Date: 3/21/2012
Subject: Re: streaming c programs
Hi Brad,
Could you be more specific on what issue you are trying to address? I don't think the file IO is significant.
Group: DynoMotion
Message: 4282
Date: 3/21/2012
Hello Tom,
It may not be an issue(IO latency), I am just trying to ‘stream’line the process of uploading c code to the controller.
I want to be able to upload and execute many different programs at will and not have to worry about when/where files are being written if possible.
It would be great if I could load some programs as strings and just compile/pump them into a thread. Even better would be to precompile programs into a collection and just dump/execute as quickly as possible.
After having a look at COFF.cpp and CLOAD.cpp it seems that it would be a lot of work separating the file logic from the buffer ….. bummer.
-Brad
From: DynoMotion@yahoogroups.com [mailto:DynoMotion@yahoogroups.com] On Behalf Of Tom Kerekes Sent: Wednesday, March 21, 2012 12:01 PM To: DynoMotion@yahoogroups.com Subject: Re: [DynoMotion] streaming c programs
Hi Brad,
Thoughts?
-Brad Murry
Group: DynoMotion
Message: 4283
Date: 3/21/2012
Brad,
RAMDisk?
Ray L.
> Hello Tom,
> It may not be an issue(IO latency), I am just trying to âstreamâline the process of uploading c code to the controller.
> After having a look at COFF.cpp and CLOAD.cpp it seems that it would be a lot of work separating the file logic from the buffer â¦.. bummer.
> -Brad
> Hi Brad,
> Sent: Wednesday, March 21, 2012 11:47 AM
> Subject: [DynoMotion] streaming c programs
> Hello Tom,
> Thoughts?
> -Brad Murry
